I strugle to get filters working properly.
Can someone tell me what the line with "if X % full" should look like?
I enclosed a screenshot. (I have not checked the "run in background" on purpose, so I can test filter)
V.1.34.2 running as a docker on an unraid server.
Filter and delete after x days
- zm-filer-delete.png (353.63 KiB) Viewed 3510 times
Re: Filter and delete after x days
Less than or equal to -14 day
Instead of disk space might try the one about storage. But leave the disk space out to test if the first part of the filter works.
Thank you for your reply.
First, should the "Start Date/Time" less than 14 days ago" be changed to "less than -14 day
I have a dedicated disk for the events, an outside of array SSD, so I do not need to spin up all disks in the Unraid-setup.
But if "Storage" is an better option, I'll try that one.
If anyone have a screenshot of a working filter, please post
I've also tested this format on a server that has a 2nd "storage" drive. Did not have to specify the storage.
Note: you need to leave the purge when full filter as it is (possibly set to 85% vice 95%) as a backup in case your other day purge does not work.
