I updated zm 1.32.3 to 1.34.2 and installed all update what released. Last update was 1.34.5.
I used individual language setup for users but after update all user language are default. I can not change it but removed the comment two row in skin.php.
I restarted zm, deleted user and create it newly nothing changed. Please help.
Ubuntu 18.04 x86_64, zm 1.34.5
Thanks for help.
User's language can not setup
Re: User's language can not setup
Selecting languages works for me.
Is anything logged?
Which language are you selecting?
Is anything logged?
Nothing logged... The setting appears to the user, but the interface language does not change and there is nothing in the log.
I tried Hungarian (hu_hu) and German (de_de) languages for user.
If I change LANG_DEFAULT then default language change but can't change individual language for user...
Confirmed. I will investigate.
Problem found, fix will be in 1.34.6
Thank you for your help.
zm 1.34.6 update arrived tonight but the user language selection still does not work...
What is the problem?
Tanks for help.
Regards
Tanks for help.
Regards
