Page 1 of 1
Changing Run State changes source function to none
Posted: Fri Feb 28, 2020 5:58 pm
by kjr1995
I'm running version 1.34.5 in docker. I've got two sources setup: a remote HTTP source and an ffmpeg rtsp stream setup. When I change the run state in the web ui, it changes my rtsp source function from monitor to none.
Re: Changing Run State changes source function to none
Posted: Fri Feb 28, 2020 8:37 pm
by bbunge
When you set up the run state were your monitor(s) set to none?
Change the monitor from none then save the run state.
Posted: Fri Feb 28, 2020 10:14 pm
by kjr1995
To be sure I am doing this correctly, I need to reenter the state name in the new state box and click save correct? Otherwise the save button is grayed out and inactive.
