Upgrade from older versions
alabamatoy
Post by alabamatoy »
I have a very reliable 1.30.0 that's been running for a couple years. Is there an upgrade path or do I need to remove and reinstall as though new?
Re: Upgrade from older versions
I upgraded a 1.30.4 on Bionic with no issues. Was just a test as I had upgraded the hardware with a newer PC. Still, I feel the upgrade would have run well.
Any upgrade should go relatively smoothly. Please note that in 1.30 to 1.32 we introduced apache config changes. You will find endless posts about it here.
Should you have problems and not find the help you need here, you can always pay me to fix it for your.
Just make sure you have a backup of your database.
And turn off zmaudit.
vvchumanov
Post by vvchumanov »
Why don't works whis>...?? /ZM say to wrong pass.
i'm change in mysql password for admin, but in web /zm don't enter (write to wrong password!!) (in mariadb it's ok work) whats troubles zm this fall change password after update 1.32 > 1.34 :roll:
but in zmninja from api it's work great :/
