Recording not working properly after upgrade to 1.34
sblectric
Post by sblectric »
I upgraded my Zoneminder from 1.30 to 1.34 and monitoring still works great, however I am getting camera disconnect/reconnect errors that I was not getting before when I try to record. New events are created every few seconds due to this.
Relevant log excerpt:
03/05/20 13:41:55.923238 zma_m1[17454].INF-zm_monitor.cpp/1615 [Front Yard: 2584 - Opening new event 173707, alarm start]
03/05/20 13:41:56.149892 zma_m1[17454].INF-zm_monitor.cpp/1648 [Front Yard: 2585 - Gone into alert state]
03/05/20 13:41:56.584904 zma_m1[17454].WAR-zm_monitor.cpp/1423 [Signal: Lost]
03/05/20 13:41:56.636492 zma_m1[17454].INF-zm_monitor.cpp/1425 [Front Yard: 2602 - Closing event 173707, signal loss]
03/05/20 13:41:56.780678 zma_m1[17454].WAR-zm_monitor.cpp/1423 [Signal: Reacquired]
03/05/20 13:41:56.815380 zma_m1[17454].INF-zm_monitor.cpp/1564 [Front Yard: 2603 - Gone into alarm state PreAlarmCount: 0 > AlarmFrameCount:1 Cause:Signal]
03/05/20 13:41:56.914653 zma_m1[17454].INF-zm_monitor.cpp/1615 [Front Yard: 2603 - Opening new event 173708, alarm start]
03/05/20 13:41:57.124671 zma_m1[17454].INF-zm_monitor.cpp/1648 [Front Yard: 2604 - Gone into alert state]
03/05/20 13:41:59.559947 zma_m1[17454].WAR-zm_monitor.cpp/1423 [Signal: Lost]
03/05/20 13:41:59.596834 zma_m1[17454].INF-zm_monitor.cpp/1425 [Front Yard: 2668 - Closing event 173708, signal loss]
03/05/20 13:41:59.730662 zma_m1[17454].WAR-zm_monitor.cpp/1423 [Signal: Reacquired]
03/05/20 13:41:59.789194 zma_m1[17454].INF-zm_monitor.cpp/1564 [Front Yard: 2669 - Gone into alarm state PreAlarmCount: 0 > AlarmFrameCount:1 Cause:Signal]
I am not trying to motion detect or anything, just want a continuous recording which worked flawlessly before upgrading.
Cam used is a HOSAFE ethernet camera using an RTSP 264 stream.
Am I missing something?
Re: Recording not working properly after upgrade to 1.34
what is interesting is you posted the motion detection logs and not the capturing logs.
sblectric
Post by sblectric »
Could it be trying to motion detect for some reason? I attached a screenshot of part of the event list below.
