ZMEventnotification should i be able to see results in web interface
bovnet
Post by bovnet »
I have the recognition working and see object.jpg, bounding box, etc being stored in events but should these result be viewable in the web interface ?
asker
Re: ZMEventnotification should i be able to see results in web interface
Post by asker »
Yes assuming you've set up the right options in zmeventnotification.ini (pass event path)
Please read before posting:
ES docs
zmNinja docs
bovnet
Post by bovnet »
hook_pass_image_path=yes and write image in objectnotification.ini set
Forgot to say multiserver install
asker
Post by asker »
Then they should show up as part of your events screen
If not, check debug logs
Screen Shot 2020-03-08 at 1.23.58 PM.png (444.84 KiB) Viewed 5075 times
ES docs
zmNinja docs
bovnet
Post by bovnet »
Got it thanks
