Page 1 of 1
ZMEventnotification should i be able to see results in web interface
Posted: Sun Mar 08, 2020 2:19 pm
by bovnet
I have the recognition working and see object.jpg, bounding box, etc being stored in events but should these result be viewable in the web interface ?
Re: ZMEventnotification should i be able to see results in web interface
Posted: Sun Mar 08, 2020 2:55 pm
by asker
Yes assuming you've set up the right options in zmeventnotification.ini (pass event path)
Posted: Sun Mar 08, 2020 5:21 pm
by bovnet
hook_pass_image_path=yes and write image in objectnotification.ini set
Forgot to say multiserver install
Posted: Sun Mar 08, 2020 5:25 pm
by asker
Then they should show up as part of your events screen
If not, check debug logs
- Screen Shot 2020-03-08 at 1.23.58 PM.png (444.84 KiB) Viewed 5078 times
Posted: Mon Mar 09, 2020 7:03 pm
by bovnet
Got it thanks
