Ive moved to a new NAS. I used to have Ubuntu with ZM 1.34 and the API worked fine. Now in ZMNinja the API fails.
It says ZMController.php not found but ZmController.php doesnt exist and didnt exist in the working config either.
I found a similar post here: https://github.com/pliablepixels/zmNinja/issues/300
Here is the output from the page
CakePHP: the rapid development php framework
Missing Controller
Error: ZmController could not be found.
Error: Create the class ZmController below in file: app/Controller/ZmController.php
<?php
class ZmController extends AppController {
Notice: If you want to customize this error message, create app/View/Errors/missing_controller.ctp
Stack Trace
APP/webroot/index.php line 107 → Dispatcher->dispatch(CakeRequest, CakeResponse)
CakePHP 2.10.8
root@zoneminder:/usr/local/www/zoneminder/api/app/Controller # ls -la
total 129
drwxr-xr-x 3 www www 19 Mar 11 13:26 .
drwxr-xr-x 11 www www 12 Mar 13 11:44 ..
-rw-r--r-- 1 www www 3694 Dec 8 2018 AppController.php
drwxr-xr-x 2 www www 6 Mar 11 13:26 Component
-rw-r--r-- 1 www www 3270 Dec 8 2018 ConfigsController.php
-rw-r--r-- 1 www www 1353 Dec 8 2018 ControlsController.php
-rw-r--r-- 1 www www 12162 Dec 8 2018 EventsController.php
-rw-r--r-- 1 www www 2516 Dec 8 2018 FramesController.php
-rw-r--r-- 1 www www 3472 Dec 8 2018 GroupsController.php
-rw-r--r-- 1 www www 5584 Dec 8 2018 HostController.php
-rw-r--r-- 1 www www 2383 Dec 8 2018 LogsController.php
-rw-r--r-- 1 www www 11289 Dec 8 2018 MonitorsController.php
-rw-r--r-- 1 www www 2123 Dec 8 2018 PagesController.php
-rw-r--r-- 1 www www 3697 Dec 8 2018 ServersController.php
-rw-r--r-- 1 www www 3646 Dec 8 2018 StatesController.php
-rw-r--r-- 1 www www 3776 Dec 8 2018 StorageController.php
-rw-r--r-- 1 www www 3777 Dec 8 2018 UsersController.php
-rw-r--r-- 1 www www 2654 Dec 8 2018 ZonePresetsController.php
-rw-r--r-- 1 www www 4608 Dec 8 2018 ZonesController.php
Im running 1.32.3 in a Freenas 11.3 jail built as a plugin.
Everything else works just no API.
I followed the guide here and fixed the errors regarding the logs and disabled the rewrites
viewtopic.php?t=28189
API Not Working
Re: API Not Working
Can anyone help here please?
Zmninja closed my issue saying this was a zoneminder/freenas issue not a zmninja issue which i agree as the API wont load in a browser either.
https://github.com/pliablepixels/zmNinja/issues/907
I've googled for answers but just finding the same pages ive already read.
Re: API Not Working
FYI there seems to be another thread right above yours viewtopic.php?f=38&t=28189
May want to consolidate there?
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Re: API Not Working
Thanks.
I've put my message into the main post to see if i get an answer there.
I guess i cant delete this post?
