Unusable picture (b/w and shifted) using 1.34
tarkhil
Post by tarkhil »
Hello
I have two cams and perfectly working with them ZoneMinder 1.30. I've built 1.34, reconnected and got totally unusable picture.
First, it's b/w instead of color.
Second... I don't know how to name it in English.
https://alpha.infotel.ru/index.php/s/tySeb9OtJnEP4EU
I have no idea on how could it be and what to do...
Re: Unusable picture (b/w and shifted) using 1.34
Check you colour/width/height in the monitor settings. They are wrong. Your logs are probably telling you this.
tarkhil
Post by tarkhil »
Originally, it was the same 1780x720 24 bit colour. Nothing usable found in logs, setting color to 256 gray or 32 bit colour yields less usable picture (with color in 32-bit mode, though)
Bluemax
Post by Bluemax »
Change the 1280 in +/-8 steps like 1272, 1288, 1296... The skew should reduce in one direction.
mikb
Post by mikb »
(Assuming your doors are vertical!)
Zooming in, it looks like it's off by *1* pixel per line (declared width 1 pixel less than actual width), and it IS in colour, but seems to be using some weird colour palette of 7 pastel colours, which is not the best ...
