hi,
I've a FPS problem with the version 1.34.6, the system gives one new frame/image 5 in 5 seconds.
The version 1.32 works fine with the same source address.
The Source Type: ffmpeg and source path: http://admin:xpto@192.168.1.101/snapsho ... sword=xpto
The camera is ...Have any different config in the version 1.34? Any solution?
Re: new frame/image 5 in 5 seconds
Do not understand what you mean by "one new frame/image 5 in 5 seconds"? If you mean key frame interval every 5 seconds that is set at the camera.cunha wrote: ↑Tue Mar 24, 2020 7:46 pm hi,
Your Source path should be: http://192.168.1.101/snapshot?account=a ... sword=xpto or http://admin:xpto@192.168.1.101/snapshot You should not have the user and password in twice.
Sorry for my bad English.
what i mean is that the image only updates every 5 seconds in version 1.34 and in 1.32 it updated every second. If someone passes in front of the camera within 5 seconds the camera does not catches the right moment
I understand.
Please tell us what Linux Distro and version.
What camera are you using?
linux distro is ubuntu server 18.04
camera is Szsinocam 5007w20 same as the attachment
- szsinocam-sn-nvk-5007w20-wireless-nvr-kit-with-four-1080p-cameras-47244.jpg (44.14 KiB) Viewed 1743 times
