Page 1 of 1
/dev/v4l/by-path not supported in device path?
Posted: Sat Mar 28, 2020 5:51 pm
by C0ng0Blu3
I am trying to use absolute path to the cameras, just in case the sources get swapped around between reboots.
But setting device source from /dev/video2 to /dev/v4l/by-path/pci-0000:01:01.2-usb-0:1:1.0-video-index0
does not seem to bring the camera up.
Re: /dev/v4l/by-path not supported in device path?
Posted: Sun Mar 29, 2020 4:56 pm
by iconnor
Should work.
Posted: Mon Mar 30, 2020 5:02 pm
by C0ng0Blu3
iconnor wrote: Sun Mar 29, 2020 4:56 pmShould work.
Hmmm, i will look @ the deb source.
running debian sid, using ZM-1.34.6...
Maybe i thought it was a field length problem, tried /dev/././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././././video0
and that still worked :)
But, the devices: /dev/v4l/by-path/"device" are symlinks to /dev/"device", Could this be a limitation from the database?
Getting this from log:
2020-03-30 09:50:43 zma_m2 374046 ERR Got empty memory map file size 0, is the zmc process for this monitor running?
2020-03-30 10:00:26 zmdc 1863 ERR 'zma -m 2' exited abnormally, exit status 255
P.S. ( slightly off this topic)
The media server was running weird last night, stopped responding, crashed on reboot, would not restart from remote location.
I am running AoE to that appliance for the OS and nfs4 for the pictures dir to my main server...
Went out to the shed with a keyboard and monitor ( where it resides) , the machine was reporting ram errors from post,
Checked each ram stick one at a time, all seem to be ok.
Turns out the processor was dying. ( the memory controller logic ?northbridge? was on its way out )
So i used the pre-upgrade part and it is behaving normally again.
Posted: Mon Mar 30, 2020 5:32 pm
by C0ng0Blu3
Having a look @ README.md in section ## Contribution Model and Development...
Looks a bit intimidating.
I have never done anything with git-pulls or code Contribution yet.
If i find or apply a fix, could/would you or somebody else that is a developer here apply a patch from me?
Posted: Mon Mar 30, 2020 5:50 pm
by C0ng0Blu3
Currently looking in zm_local_camera.h
Might as well grep for it.
~/deb-src/zoneminder-1.34.6/src# grep -r video0 .
./zmc.cpp: -d, --device <device_path> - For local cameras, device to access. e.g /dev/video0 etc
./zmc.cpp: fprintf(stderr, " -d, --device <device_path> : For local cameras, device to access. E.g /dev/video0 etc\n");
I dunno the cpp :? I have written a little embedded/gnu C some years back...
Posted: Mon Mar 30, 2020 6:26 pm
by iconnor
You are going to want to turn on debugging under Options->Logging.
I will apply your patch if need be.
Posted: Mon Mar 30, 2020 6:36 pm
by C0ng0Blu3
I guess I am close?
~/deb-src/zoneminder-1.34.6/src# grep -r device.c_str .
./zm_local_camera.cpp: Debug(3, "Opening video device %s", device.c_str());
./zm_local_camera.cpp: //if ( (vid_fd = open( device.c_str(), O_RDWR|O_NONBLOCK, 0 )) < 0 )
./zm_local_camera.cpp: if ( (vid_fd = open(device.c_str(), O_RDWR, 0)) < 0 )
./zm_local_camera.cpp: Fatal("Failed to open video device %s: %s", device.c_str(), strerror(errno));
./zm_local_camera.cpp: if ( stat(device.c_str(), &st) < 0 )
./zm_local_camera.cpp: Fatal("Failed to stat video device %s: %s", device.c_str(), strerror(errno));
./zm_local_camera.cpp: Fatal("File %s is not device file: %s", device.c_str(), strerror(errno));
./zm_local_camera.cpp: if ( (enum_fd = open(device.c_str(), O_RDWR, 0)) < 0 ) {
./zm_local_camera.cpp: device.c_str(), strerror(errno));
./zm_ffmpeg_camera.cpp: (hwaccel_device != "" ? hwaccel_device.c_str(): NULL), NULL, 0);
./zm_ffmpeg_camera.cpp: Debug(1, "Created hwdevice for %s", hwaccel_device.c_str());
I can't seem to follow device.c_str()
Is there any other way to get guaranteed device persistence using local UVC webcams?
Posted: Mon Mar 30, 2020 6:56 pm
by C0ng0Blu3
2020-03-30 11:53:16 zmwatch 2060 ERR Unable to run "/usr/bin/zmdc.pl restart zmc -d /dev/v4l/by-path/pci-0000:00:02.1-usb-0:5:1.0-video-index0", output is "", status is 255 zmwatch.pl
LOL export log file for attachment -> txt says:
Export Failed: 500 / Internal Server Error
OK i think export log.txt current zmwatch? attachment.
zm-log.txt
(26.53 KiB) Downloaded 289 times
Posted: Mon Mar 30, 2020 10:00 pm
by iconnor
So zmwatch is unhappy, but that tells us nothing about why it isn't capturing. You need zmc logs. With debug on.
Please note that my local cams work fine with either /dev/video0 or the /dev/v4l/by-id string.
Posted: Tue Mar 31, 2020 7:54 am
by C0ng0Blu3
Cannot seem to output the whole debugging log, when exporting to txt file the page has a little white box and
does not give me any kind of output.
zm-log (4).txt
(26.56 KiB) Downloaded 207 times
zm-log (5).txt
(38.61 KiB) Downloaded 196 times
zm-log (6).txt
(19.46 KiB) Downloaded 350 times
I made sure in options/logging that debugging was turned on.
Posted: Tue Mar 31, 2020 8:13 am
by C0ng0Blu3
iconnor wrote: Mon Mar 30, 2020 10:00 pm So zmwatch is unhappy, but that tells us nothing about why it isn't capturing. You need zmc logs. With debug on.
I have 2 webcams that are the same.
by-id:
lrwxrwxrwx 1 root root 12 Mar 29 16:54 usb-Vimicro_Corp._Venus_USB2.0_Camera-video-index0 -> ../../video2
lrwxrwxrwx 1 root root 12 Mar 29 16:54 usb-Vimicro_Corp._Venus_USB2.0_Camera-video-index1 -> ../../video3
by-path:
lrwxrwxrwx 1 root root 12 Mar 29 16:54 pci-0000:00:02.1-usb-0:5:1.0-video-index0 -> ../../video0
lrwxrwxrwx 1 root root 12 Mar 29 16:54 pci-0000:00:02.1-usb-0:5:1.0-video-index1 -> ../../video1
lrwxrwxrwx 1 root root 12 Mar 29 16:54 pci-0000:01:01.2-usb-0:1:1.0-video-index0 -> ../../video2
lrwxrwxrwx 1 root root 12 Mar 29 16:54 pci-0000:01:01.2-usb-0:1:1.0-video-index1 -> ../../video3
video0 is the inside cam and video2 the outside one.
video1 and video3 are control channels.
by-id does not work at all for me.
I guess i could set it back to use /dev/video~ but it would be nice to have device persistence.
