Page 1 of 1
zmninja iOS 13.4 update
Posted: Fri Apr 10, 2020 6:40 pm
by sipi
I updated iOS on my iPhone then arrived an zmninja update and updated it too.
After this updates I didn't find my server in app (the configured servers are gone) and I can't setup it because can't be saved (nothing happens).
What happened?
Thank for your help.
Re: zmninja iOS 13.4 update
Posted: Fri Apr 10, 2020 6:48 pm
by asker
I'm not sure - I've started the update process to 13.4 to see if the new OS broke anything. Will update here.
Posted: Fri Apr 10, 2020 7:41 pm
by asker
I just updated to iOS 13.4.1 and had no issues.
Do the following:
a) In zmNinja, clear API cache (Menu)
b) Exit the app
c) Go to ZoneMinder, to Options->API and click "Revoke all tokens"
d) Then run zmNinja
If you don't see your server, run Wizard (in my case, none of my settings were removed)
Posted: Fri Apr 10, 2020 8:17 pm
by sipi
thank you for your quickly answer but in the meantime, i upgraded to iOS 13.4.1 and nothing changed.
My server settings are gone and I can't create a new one. Unable to save server settings ... I click Save, but nothing happens. The configured server is not listed.
Thank you for your help.
Posted: Fri Apr 10, 2020 8:19 pm
by asker
Okay, try this:
1) Start zmNinja, go to settings, disable "Cloud backup", save
2) Exit app
3) Delete app from device
4) Install again
5) Use wizard
Posted: Fri Apr 10, 2020 8:35 pm
by sipi
thank you for your help, problem is solved.
Your advice for reinstall was successful.
Thank you for very quickly help and solution. Many thanks.
Kind Regards
Posted: Fri Apr 10, 2020 9:18 pm
by asker
Sounds good!
