Page 1 of 1
ZmNinja Pictures
Posted: Sun Apr 12, 2020 2:16 pm
by NXT
Is it possible to send notifications images to iPhone?
Do you have to remove the “picture_url” in the zmnotification.ini? Or does Hooks have to be activated to receive notification images?
Thanks!
Have a nice day everyone!
Re: ZmNinja Pictures
Posted: Sun Apr 12, 2020 3:46 pm
by asker
Yes it is.
The picture_url field has to be specified (read comments above it).
Sending images does not need hooks.
Posted: Sun Apr 12, 2020 5:46 pm
by NXT
Thanks for the response.
Do I also have to change settings in de secret.ini file?
Posted: Sun Apr 12, 2020 7:14 pm
by NXT
Ok its working.
I had this.
picture_url = https://XXXXX:port/zm/index.php?view=image&eid=EVENTID&fid=BESTMATCH&width=600
picture_url = https://XXXXX:port/zm/index.php?view=image&eid=EVENTID&fid=objdetect&width=600
picture_url = https://XXXXX:port/zm/index.php?view=image&eid=EVENTID&fid=snapshot&width=600
picture_url = https://XXXXX:port/zm/index.php?view=image&eid=EVENTID&fid=alarm&width=600
That wasn't working.
Now I'm only using this one.
And works like a charm!
Another question is it possible to turn off the notification events when its seeing a dog or a specific numberplate?
Thanks!
Posted: Sun Apr 12, 2020 8:50 pm
by asker
You can use detect_pattern in objectconfig.ini to filter out dog. But that would mean it won't identify a dog either.
Posted: Sun Apr 12, 2020 9:16 pm
by NXT
I have a camera on my dog but I’m getting to much notifications if she moves
is there another solution?
And for the numberplate I have to install more then Hooks only I suppose?
Thanks for the fast response!
Posted: Mon Apr 13, 2020 8:59 pm
by asker
You can reduce the # of notifications you get by reducing the reporting frequency. You can do that by going to zmNinja->Settings->Event server settings and changing reporting frequency. zmNinja help is here:
https://docs.google.com/document/d/e/2P ... M9Hz8p/pub
Number plate - please read the docs here
https://zmeventnotification.readthedocs ... ecognition
Requires setup depending on which service you want to use.
In general, please read docs thoroughly
