Montage Review, all monitors show "Camera Offline"
IncompleteString
Post by IncompleteString »
I've been having an issue on where if the montage review is left open for an extended period of time all the monitors will show as "Camera Offline". Refreshing the page brings the video feed back for all the monitors.
Does anyone have ideas about how to fix this?
ZM Version: 1.34.9
OS. Ubunbu 16.04
burger
Re: Montage Review, all monitors show "Camera Offline"
Post by burger »
In 1.30.4, Typically you will use a refresh command (e.g. xdotool f5) to resolve any dropouts on cameras. I should note, that I don't use montage review, but use this:
https://wiki.zoneminder.com/Example_Camera_View_HTML
fastest way to test streams:
guanche
Post by guanche »
IncompleteString wrote: Fri Apr 17, 2020 7:07 am I've been having an issue on where if the montage review is left open for an extended period of time all the monitors will show as "Camera Offline". Refreshing the page brings the video feed back for all the monitors.
ZM Version: 1.34.9
OS. Ubunbu 16.04
Same problem here after update... :| :| :(
I hope it will get solved soon...
ZM Version: 1.34.22
OS. Ubunbu 20.04 LTS
Regards
guanche
Industrial6
Post by Industrial6 »
This is still an issue an issue with 1.34.23
