Helo configuring XM530 BESDER
Posted: Fri Apr 17, 2020 12:47 pm
Hello to all,
I've purchased two BESDER PTZ CAMs:
https://www.aliexpress.com/item/3303835 ... 4c4d69ZdPx
I'm testing it succesfully using the "OnVIF Device Manager 2.2.250". I can see thise CAM informations:
Manifacturer: H264
Model: XM530_80X20_8M
Firmware: V5.00.R02.00030678.10010.244500..ONVIF 2.41
ONVIF Version: 2.41
With this App I'm able to see live stream, use PTZ and Zoom.
Now, I'm trying to add it to Zoneminder. The Onvif discover works, and the stream too. BTW I've no idea how let the PTZ and Zoom work on Zoneminder.
I've tested the ONVIF profile and netcat ONVIF, but no luck.
With the ONVIF program under Windows it works well.
Can someone help me?
Thanks!
Simon
Manifacturer: H264
ONVIF Version: 2.41
Thanks!
Simon
