Upgrade from 1.30.4 to 1.34.x gets me 1.32.2
SkippyDo
Post by SkippyDo »
(After a successful upgrade of my OS to Debian Buster...)
I'm upgrading ZM from 1.30.4 to 1.34.x using info from here: viewtopic.php?f=40&t=28969#p113415 I seem to be getting/installing ZM 1.32.3 instead of 1.34.x.
Keyring add worked, though I had to re-run due to improper command syntax provided in above posting.
sudo apt list | grep zoneminder
mythzoneminder/stable 1:30.0+fixes20200310.gitab250d6ccf-dmo1 amd64
zoneminder-dbg/buster 1.34.9-buster1 amd64
zoneminder-dbg/buster 1.34.6-buster1 armhf
zoneminder-doc/stable 2:1.32.3-dmo4+deb10u2 all
zoneminder/stable,now 2:1.32.3-dmo4+deb10u2 amd64 [installed]
zoneminder/buster 1.34.6-buster1 armhf
Entry in /etc/apt/sources.list:
Output from re-running sudo apt-get update:
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster-updates InRelease
Hit:3 http://deb.debian.org/debian buster InRelease
Hit:4 http://deb.debian.org/debian-security buster/updates InRelease
Ign:5 https://zmrepo.zoneminder.com/debian/release-1.34 buster/ InRelease
Hit:6 https://zmrepo.zoneminder.com/debian/release-1.34 buster/ Release
Hit:8 http://deb-multimedia.org buster InRelease
Reading package lists... Done
Output from re-running sudo apt-get upgrade:
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Running sudo /usr/bin/zmupdate.pl gives:
Initiating database upgrade to version 1.32.3 from version 1.30.4
Please ensure that ZoneMinder is stopped on your system prior to upgrading the database.
Press enter to continue or ctrl-C to stop : ^C
Am I looking at having to uninstall ZM and then install 1.34? I have a backup of my DB (from 1.30.4).
SkippyDo
Re: Upgrade from 1.30.4 to 1.34.x gets me 1.32.2
Post by SkippyDo »
I've deleted and re-imported the keys for ZM and re-ran update. No change.
Deleted current ZM installation and did an INSTALL and STILL I am ending up with 1.32!
SkippyDo
Post by SkippyDo »
Finally resorted to deleting ZM and installing it via:
sudo apt-get install zoneminder=1.34.10-buster1
This appears to have worked (update DB and all).
Yup, I warned about this a couple days ago!
SkippyDo
Post by SkippyDo »
Hm... I looked all over but didn't spot that. Sorry.
Tomm
Post by Tomm »
bbunge wrote: Wed Apr 29, 2020 2:23 am Yup, I warned about this a couple days ago!
Before I dive onto this same procedure... what is the warning exactly ? I've gone & looked at your posts from just prior to Apr29 but haven't found it ?
