what' wrong?
what' wrong?
I have now running zm version 1.29 on a Pi3.
I'am installing a new pi4 with Zm version 1.34.10.
In attach the 2 configurations.
Both are set exact the same values but the new version is not working.
I have copied the settings from the working camera to the new version.
Below a part of the log file.
2020-05-01 11:09:18 zmc_m1 14335 ERR Unrecognised content type 'text/plain' zm_remote_camera_http.cpp 848
2020-05-01 11:09:18 zmc_m1 14335 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1085
2020-05-01 11:09:18 zmc_m1 14335 INF Return from Capture (-1), signal loss zm_monitor.cpp 2454
2020-05-01 11:09:18 zmc_m1 14335 INF Failed to capture image from monitor 1 F19803P (1/1) zmc.cpp 317
2020-05-01 11:09:13 zmc_m1 14335 ERR Unrecognised content type 'text/plain' zm_remote_camera_http.cpp 848
2020-05-01 11:09:13 zmc_m1 14335 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1085
2020-05-01 11:09:13 zmc_m1 14335 INF Return from Capture (-1), signal loss zm_monitor.cpp 2454
What can be wrong in this configuration.
I use a Foscam F19803P camera.
The small figure is the working version
- working2.png (22.2 KiB) Viewed 5025 times
- ZM v1.34.10
- NOTworking2.png (36.39 KiB) Viewed 5025 times
Re: what' wrong?
I've got the same camera and it's working.
I attached screenshots with configs.
On the source path line where I darkened you have to write "username:password"
- Cattura2.JPG (54.01 KiB) Viewed 5018 times
- Cattura.JPG (59.21 KiB) Viewed 5018 times
Production: zm 1.34.26 - Debian 11 | Test: zm 1.36.33 - Debian 12
Re: what' wrong?
Thanks,
I have put the setting like yours (with my username password), but is still not showing an image.
Is there a way to test it another way?
I have tried in VLC and it is not working there also.
BUT, when i use the path "http://192.168.0.99:99/cgi-bin/CGIProxy ... &pwd=xxxxx&" in a browser, its working.
What do i missing?
Herman
What do i missing?
Herman
- vooraan.png (291.13 KiB) Viewed 5013 times
Re: what' wrong?
I don't know. I've got POE version and rtsp stream is working on vlc.
- Cattura.JPG (41.21 KiB) Viewed 5009 times
Re: what' wrong?
This a part of my /var/log/messages file
May 1 14:55:03 raspberrypi zmc_dvideo0[5368]: INF [zmc_dvideo0] [Starting Capture version 1.34.10]
May 1 14:55:08 raspberrypi zmc_m1[5222]: INF [zmc_m1] [Priming capture from rtsp://xxx:pppppp@192.168.0.99:99/videoMain]
May 1 14:55:18 raspberrypi zmc_m1[5222]: INF [zmc_m1] [Priming capture from rtsp://xxx:pppppp@192.168.0.99:99/videoMain]
May 1 14:55:28 raspberrypi zmc_m1[5222]: INF [zmc_m1] [Priming capture from rtsp://xxx:pppppp@192.168.0.99:99/videoMain]
May 1 14:55:38 raspberrypi zmc_m1[5222]: INF [zmc_m1] [Priming capture from rtsp://xxx:pppppp@192.168.0.99:99/videoMain]
So it looks that is it working but why i don't see an image then
Herman
Herman
Re: what' wrong?
See: https://wiki.zoneminder.com/Foscam_FI9803EP for settings for your camera.hv0805 wrote: ↑Fri May 01, 2020 12:58 pm This a part of my /var/log/messages file
Herman
Also start with a lower resolution. Try half of the values you entered. Go back to VLC with the path rtsp://[LOGIN]:[PASSWORD]@10.0.0.11:88/videoMain and check the reported camera resolution
And your camera is a FI9803P not a F19803P
Re: what' wrong?
thanks,
I have already start from 0. It is a brand new installation of pi4 with nothing else installed. I see error messages on the console about Mysql ([HY000] [1045] Access denied for user 'root'@'localhost' (using password: NO) and i don't able to solve this problem, so i start from 0.
Perhaps i will reset my camera also because i cannot login to the setup screen from the camera.
Herman
Herman
Re: what' wrong?
May I recommend the Raspberry Pi Imager: https://www.raspberrypi.org/blog/raspbe ... g-utility/hv0805 wrote: ↑Fri May 01, 2020 2:34 pm thanks,
Herman
I set up my Pi 3 yesterday with Ubuntu 20.04 64 bit version and Zoneminder 1.34.10
You really do not need to make any modifications to the Ubuntu install but I remove the cloud stuff and enable WIFI. Can provide instructions if needed. And do not use the Pi with a desktop!
Re: what' wrong?
Thanks, my pi4 is just reinstalled and tomorrow i Will do the zoneminder stuff. I think i made An mistake in the mariadb config with the passwords. I see it tomorrow.
Re: what' wrong?
I'am installing a brand new system now but this time i have the following message:
This is the content of sources.list
deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
deb https://zmrepo.zoneminder.com/debian/release-1.34 buster/
This is the error is receive: by the next command: deb https://zmrepo.zoneminder.com/debian/release-1.34 buster/
pi@pi4:/var/log/apache2 $ sudo apt install apt-transport-https gnupg
Reading package lists... Done
Building dependency tree
Reading state information... Done
apt-transport-https is already the newest version (1.8.2).
gnupg is already the newest version (2.2.12-1+rpi1+deb10u1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@pi4:/var/log/apache2 $ wget -O - https://zmrepo.zoneminder.com/debian/ar ... eyring.gpg | sudo apt-key add -
--2020-05-02 09:21:35-- https://zmrepo.zoneminder.com/debian/ar ... eyring.gpg
Resolving zmrepo.zoneminder.com (zmrepo.zoneminder.com)... 69.165.169.197
Connecting to zmrepo.zoneminder.com (zmrepo.zoneminder.com)|69.165.169.197|:443... connected.
HTTP request sent, awaiting response... 403 Forbidden
2020-05-02 09:21:36 ERROR 403: Forbidden.
gpg: no valid OpenPGP data found.
on the website from the wiki installation i cannot go to the repo via the symbol just behind "archive-keyring.gpg"
Yesterday this was working.
Is there a problem with the website by Zoneminder or is it a problem with me?
Herman
Herman
Re: what' wrong?
Just installed my Pi 3 with Buster and Zoneminder per: https://wiki.zoneminder.com/Debian_10_B ... -1.34_Repo
No issues...successful install. Just remember to prepend commands with sudo
Re: what' wrong?
It's WORKING
I found a PDF from Foscam with cgi scripts. Via this way i was able to find the usernames and password configured on the camera.
I enabled also rtsp and are now connected via rtsp.
I'am happy.
Herman
I'am happy.
Herman
