I upgraded ZM to v1.34.12 yesterday and it's refused to start since then. Running jounalctl -xe after a failed start tells me the following:
May 11 15:21:09 megaserver systemd[1]: Starting ZoneMinder Video Surveillance System...
-- Subject: A start job for unit zm.service has begun execution
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- A start job for unit zm.service has begun execution.
-- The job identifier is 15008.
May 11 15:21:09 megaserver zm_database_init[3862]: INFO: when db is correctly installed and you just reinstalled rpm, then answer all questions with 'n'
May 11 15:21:09 megaserver zm_database_init[3862]: Error: User root needed to execute database init
May 11 15:21:09 megaserver systemd[1]: zm.service: Control process exited, code=exited, status=3/NOTIMPLEMENTED
-- Subject: Unit process exited
-- An ExecStartPre= process belonging to unit zm.service has exited.
-- The process' exit code is 'exited' and its exit status is 3.
May 11 15:21:09 megaserver systemd[1]: zm.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit zm.service has entered the 'failed' state with result 'exit-code'.
May 11 15:21:09 megaserver systemd[1]: Failed to start ZoneMinder Video Surveillance System.
-- Subject: A start job for unit zm.service has failed
-- A start job for unit zm.service has finished with a failure.
-- The job identifier is 15008 and the job result is failed.
# ZoneMinder database name
ZM_DB_NAME=zm
# ZoneMinder database user
ZM_DB_USER=zm_admin
# ZoneMinder database password
ZM_DB_PASS=<My super secret database password!>
megaserver:/etc # zmupdate.pl
Database already at version 1.34.12, update skipped.
megaserver:/etc # zm_database_init
database is already installed. if you want to recreate the database drop it manually!!
Too few arguments.
Error: Command 'systemctl restart ' returned non-zero exit status 1.
- /root/.my.cnf contains the root user's valid password.
- zm_admin user has been granted all necessary rights to the zm database.
- I've been unable to find any additional info in the logs.
Oh, and since it's my very first post - thank you very much to all who contribute to Zoneminder and this forum!
Regards,
Christo (the snake man)
