[solved] Service won't start on Debian 10 + ZM 1.34.15
Posted: Wed Jun 03, 2020 2:26 pm
I'm exploring Zoneminder and having a bear of a time with Debian 10 and Zoneminder 1.34.15. I followed the wiki guide here. The web interface is fine, AFAICT the database is accessible, but the Zoneminder service won't start and I'm not seeing any obvious errors in the logs/output. Below is output from starting the service, systemd logs, trying to start zmpkg.pl manually, and /var/logs/zm/stuff_that_seemed_important. I've found several troubleshooting guides and followed what seemed relevant without luck. Any advice on where to look for additional clues, or pointing out something I missed in the logs below would be much appreciated.
root@vserver:/home/jimmy# systemctl start zoneminder
Job for zoneminder.service failed because the control process exited with error code.
See "systemctl status zoneminder.service" and "journalctl -xe" for details.
root@vserver:/home/jimmy# systemctl status zoneminder.service
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Wed 2020-06-03 09:32:07 EDT; 1s ago
Process: 1581 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=1/FAILURE)
root@vserver:/home/jimmy# journalctl -xe
-- A start job for unit zoneminder.service has begun execution.
-- The job identifier is 2794.
Jun 03 09:32:17 vserver zmpkg[1598]: INF [Sanity checking States table...]
Jun 03 09:32:17 vserver zmpkg[1598]: INF [Command: start]
Jun 03 09:32:17 vserver su[1606]: (to www-data) root on none
Jun 03 09:32:17 vserver su[1606]: pam_unix(su:session): session opened for user www-data by (uid=0)
Jun 03 09:32:17 vserver systemd[1]: Started Session c17 of user www-data.
-- Subject: A start job for unit session-c17.scope has finished successfully
-- Defined-By: systemd
-- Support: https://www.debian.org/support--
-- A start job for unit session-c17.scope has finished successfully.
-- The job identifier is 2875.
Jun 03 09:32:17 vserver su[1606]: pam_unix(su:session): session closed for user www-data
Jun 03 09:32:17 vserver su[1609]: (to www-data) root on none
Jun 03 09:32:17 vserver su[1609]: pam_unix(su:session): session opened for user www-data by (uid=0)
Jun 03 09:32:17 vserver systemd[1]: Started Session c18 of user www-data.
-- Subject: A start job for unit session-c18.scope has finished successfully
-- A start job for unit session-c18.scope has finished successfully.
-- The job identifier is 2960.
Jun 03 09:32:17 vserver systemd[1]: session-c17.scope: Succeeded.
-- Subject: Unit succeeded
-- The unit session-c17.scope has successfully entered the 'dead' state.
Jun 03 09:32:17 vserver su[1609]: pam_unix(su:session): session closed for user www-data
Jun 03 09:32:17 vserver systemd[1]: session-c18.scope: Succeeded.
-- The unit session-c18.scope has successfully entered the 'dead' state.
Jun 03 09:32:17 vserver systemd[1]: zoneminder.service: Control process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- An ExecStart= process belonging to unit zoneminder.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
Jun 03 09:32:17 vserver systemd[1]: zoneminder.service: Failed with result 'exit-code'.
root@vserver:/usr/bin# zmpkg.pl version
1.34.15
root@vserver:/usr/bin# zmpkg.pl start
06/03/2020 09:55:16.513465 zmpkg[795].INF [main:310] [Sanity checking States table...]
06/03/2020 09:55:16.566363 zmpkg[795].INF [main:95] [Command: start]
06/03/2020 09:55:16.725896 zmsystemctl[801].INF [main:71] [Redirecting command through systemctl]
Job for zoneminder.service failed because the service did not take the steps required by its unit configuration.
root@vserver:/var/log/zm# cat ./zmpkg.log
06/03/2020 09:55:16.788538 zmpkg[812].INF [main:310] [Sanity checking States table...]
06/03/2020 09:55:16.790249 zmpkg[812].INF [main:95] [Command: start]
06/03/2020 09:55:18.186586 zmpkg[812].INF [main:203] [Single server configuration detected. Starting up services.]
06/03/2020 09:55:28.825673 zmpkg[926].INF [main:310] [Sanity checking States table...]
06/03/2020 09:55:28.827276 zmpkg[926].INF [main:95] [Command: start]
06/03/2020 09:55:39.071546 zmpkg[941].INF [main:310] [Sanity checking States table...]
06/03/2020 09:55:39.074625 zmpkg[941].INF [main:95] [Command: start]
.... over and over and over....
