Dahua / Alhua IPC-HDW4631C-A works
Posted: Wed Jun 03, 2020 4:35 pm
Bought this on Ebay, it's an unbranded Dahua / Alhua 6MP turret camera. This is the closest I can find on the web site: https://www.dahuasecurity.com/products/ ... 4631EM-ASE
The camera firmware viewer requires some ActiveX plugin, I didn't bother. But the settings tab works.
Works out of the box with Zoneminder 1.34. Settings:
General:
Source Type: Ffmpeg
Source:
Source Path: rtsp://USER:PASSWORD@IP_ADDRESS:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
Method: TCP
Options: [empty]
DecoderHWAccelName: [empty]
DecoderHWAccelDevice: [empty]
Target colorspace: 32 bit
Capture Resolution (pixels): 1920x1080*
*I have the resolution in the camera firmware set to 3072 x 2048, Zoneminder set to 1920 x 1080. This produces a good image. It also works with Zoneminder set to 3072 x 2048. Setting the camera firmware to 1920 x 1080 produced a horribly grainy image.
General:
Source Type: Ffmpeg
Source:
Method: TCP
Options: [empty]
