Probe not working
Beppe6464
Probe not working
Post by Beppe6464 »
Hi, i have installed ZM 1.34 on my Raspberry Pi 4 following some tutorials. It seems to be installed correctly.
Nevertheless under ADD button neither Probe link and ONVIF link are able to detect something.
On my network there are running two Foscam Fi9900p in ONVIF and one Chinese Camera on RTSP.
All signals can be captured with an Android app without problems but i'm unable to use ZM.
Whats wrong ? What can i check ?
Thank you.
Ciao.
gp
Re: Probe not working
After a review of the Foscam manual for the FI9900P camera it looks like the "usual" settings for a Foscam HD camera will work
Use ffmpeg
Source: rtsp://admin:password@IP-Address:88/videoMain
Resolution I use is 640x320 but other multiples should work.
If you can get the camera to stream in VLC use the same settings in Zoneminder.
Once you get into your cameras you may want to set the key frame interval and frame rate lower.
Beppe6464
Post by Beppe6464 »
Yes, i'm able to get the flow with VLC but if i add the same path into the ZM Add screen i get :
Monitor is not capturing. We will be unable to provide an image Monitor-2
It is like ZM was unable to retrieve the streams.
Thank you.
Ciao.
