[SOLVED] RTSP Stream will not caputred with camera LUPUS - LE221
tbalensiefer
Post by tbalensiefer »
Zoneminder v1 34.16 is not able to capture the rtsp stream from the LUPUS - LE221 (https://www.lupus-electronics.de/shop/e ... PoE-p.html).
I receive following errors
2020-06-23 11:44:54 zmc_m2 2412 ERR Unable to open input rtsp://user:pass@192.168.178.112:554/cam/realmonitor?channel=1&
subtype=0&unicast=true&proto=Onvif due to: Invalid argument zm_ffmpeg_camera.cpp
2020-06-23 11:34:14 zmc_m2 2317 ERR Failed to prime capture of initial monitor zmc.cpp 257
VLC player and ONVIFViewer are working without problems with LUPUS LE221.
RTSP stream from AXIS P1427 IP Camera works fine.
Has someone an idea what's wrong? or what should I change in my configuration.
Thank you for you hints!
Best Regards
Thomas
burger
Re: RTSP Stream will not caputred with camera LUPUS - LE221
Post by burger »
See
https://wiki.zoneminder.com/Finding_Camera_Stream_Paths
You can try source type: libVLC, if it plays in VLC.
fastest way to test streams:
f.eichentopf
Post by f.eichentopf »
try without any arguments like this: rtsp://user:pass@192.168.178.112:554
this works for my 9 Lupus LE334
tbalensiefer
finally I found out what the reason was. My password was ending with a "?" After changing my password everything is working fine.
Thank you
Thomas
