Database filling up with Logs
~Rob
Post by ~Rob »
After a few days I'm running out of disk space as the log table is becoming huge (gigabytes worth).
It seems I'm having a similar issue to this: viewtopic.php?f=38&t=28611&p=111942&hil ... og#p111942
I've set logging to be None on the database but I still see a few rows added every second.
Is this a bug/known issue or am I missing some configuration?
Re: Database filling up with Logs
You do need to restart zm for the config changes to take effect
~Rob
Post by ~Rob »
Thnaks Connor, that did the trick.
Is it just the logs that require a restart. I'll submit a PR for the logging options page with a note to restart after saving if that is the case.
