Page 1 of 1
Problems with api since installing zm 1.34.16
Posted: Wed Jul 01, 2020 5:30 am
by bairesnetwork
Hello, it is my first post, first of all I appreciate all possible collaboration. I'm a new Zoneminder user, I had version 1.34.15 and I also use zmninja. I use users with a password to authenticate. Since changing to Zoneminder version 1.34.16 I can no longer access it from zmninja, API error, I reinstalled the server thinking it was something that broke, but even with the clean installation of the server I cannot access it with zmninja. Someone had a similar problem or would you know how to guide me? From already thank you very much.
Re: Problems with api since installing zm 1.34.16
Posted: Wed Jul 01, 2020 1:30 pm
by knight-of-ni
Moved to the correct forum.
To troubleshoot your issue, please follow the API documentation here:
https://zoneminder.readthedocs.io/en/stable/api.html
To isolate where the problem lies, follow the examples to retrieve information using curl.
Posted: Wed Jul 01, 2020 5:52 pm
by bairesnetwork
Excellent, thank you very much, I do the indicated steps. best regards.
Posted: Sun Jul 05, 2020 2:33 am
by davew
I have the same issue and I just posted a lot of detailed information about my setup just recently. See link below.
viewtopic.php?f=40&t=29689
