Cannot see all logs.
LarryDana
Post by LarryDana »
After install during configuration I could see various different (6+?) log files when I was debugging my configuration. After a couple of days running I went to check the logs and now I can only see zm_monitor.cpp as a valid log "File".
What happened to all the other types of "Logs"?
I can see the camera video output (running in Monitor only currently)
This is a fresh install (clean wiped drive) on:
Dell Latitude-E6430
initial setup two USB Logitech webcams C270 and C615
Ubuntu 20.04 LTS
zoneminder v1.34.16
Note: I did click the "---" line several times, but still only the one file is listed.
