Changing rights to www-data - DropBox syncing - Permission question
Posted: Fri Jul 03, 2020 12:43 pm
Good afternoon !
I am running ZM 1.34.15 on Debian Buster.
I've been trying hard to sync my files with DropBox for a few days now. I mounted a filesystem of 2 GB, sucessfully run a filter on it but the file wouldn't be saved because it was created by www-data which is not an admin user.
I tried to add www-data to the sudo group but didn't changed. I finally tried to add it to the sudoers file (etc/sudoers), giving it ALL privileges : %www-data ALL=(ALL:ALL)ALL
And , surprise, the file synced with DropBox!
Only problem then, I was unable to launch ZM anymore ....
I removed the line from sudoers, restarted debian and still, nothing on the login page, all blank.
I did a fresh reinstall of ZM (viewtopic.php?t=26129) and reinstall according to the Wiki : https://wiki.zoneminder.com/Debian_10_B ... om_ZM_Repo.
Still nothing. I started looking at logs :
Is there a way to give the user www-data admin privileges then my files will be synced to DropBox ? (Without having to chmod every files ?)
Or is there a way for ZM to create files under the name of my admin user directly instead of using www-data ?
I am kind of confused ...
Thanks a lot for every answer !
Have a wonderful week end watching your home with ZM
- in /var/log/zm : All seems to start normally but there is no web_php.log file
- in /var/log/apache2 : I looked at the last edited error.log and got :
[Fri Jul 03 12:06:52.425429 2020] [php7:warn] [pid 629] [client 127.0.0.1:45960] PHP Warning: error_log(/var/log/zm/web_php.log): failed to open stream: Permission denied in /usr/share/zoneminder/www/includes/logger.php on line 397
[Fri Jul 03 12:06:52.425498 2020] [php7:error] [pid 629] [client 127.0.0.1:45960] PHP Fatal error: Can't write to log file '/var/log/zm/web_php.log': error_log(/var/log/zm/web_php.log): failed to open stream: Permission denied @ /usr/share/zoneminder/www/includes/logger.php/397 in /usr/share/zoneminder/www/includes/logger.php on line 400
(for different pid as well : 1386,626,627 and 1386 again)
So, from here, I created a web_php.log, giving it chmod 2775 and it started running !
- As you might expect, lots of permission problems and changing all my system files with chmod 2775 is not a solution
For example, I am now unable to open the camera unless I chmod it everytime I want to open it ...
Logs from ZM : 2020-07-03 14:21:56 zms_m1 1599 ERR Unable to connect to zmc process for monitor 1 zms.cpp 257
2020-07-03 14:21:56 zms_m1 1599 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 53
2020-07-03 14:21:56 zms_m1 1599 ERR fopen() for /var/log/zm/zms_m1.log, error = Permission denied zm_logger.cpp 418
2020-07-03 14:21:56 zms_m1 1599 ERR Can't open memory map file /dev/shm/zm.mmap.1, probably not enough space free: Permission denied zm_monitor.cpp 558
2020-07-03 14:21:55 web_php 644 ERR socket_bind( /var/run/zm/zms-973868w.sock ) failed: Permission denied /usr/share/zoneminder/www/includes/functions.php 2177
2020-07-03 14:21:54 zmc_dvideo0 885 INF Garage: images:6900 - Capturing at 25.00 fps, capturing bandwidth 30720000bytes/sec zm_monitor.cpp 2544
2020-07-03 14:21:51 zms_m1 1595 ERR Unable to connect to zmc process for monitor 1 zms.cpp 257
2020-07-03 14:21:51 zms_m1 1595 ERR Unable to connect to monitor id 1 for streaming zm_stream.cpp 53
2020-07-03 14:21:51 zms_m1 1595 ERR fopen() for /var/log/zm/zms_m1.log, error = Permission denied zm_logger.cpp 418
2020-07-03 14:21:51 zms_m1 1595 ERR Can't open memory map file /dev/shm/zm.mmap.1, probably not enough space free: Permission denied
