How to add storage area at host filesystem to zm in docker container?
Support for the docker image maintained by dlandon
andrew-yu
Post by andrew-yu »
burger
Re: How to add storage area at host filesystem to zm in docker container?
Post by burger »
This is a docker question, not a ZM question. Try docker resources.
Typically you use Volumes for this.
e.g.
nginx: image:
nginx:latest
container_name: custom_name_for_my_proxy
volumes:
 - ./nginx.conf:/etc/nginx/nginx.conf
 - /etc/letsencrypt/:/etc/letsencrypt/
 - ./webroot/:/var/www/html/
Here the first column is the host path, and the second column is the docker container's path.
fastest way to test streams:
