Axis M1031-W
Technoholic
Axis M1031-W
Post by Technoholic »
Attempting to setup the subject camera in ZM 34.16. I have everything but a password. Entering the source stream in VLC prompts for a password. Entering in ZM produces an authentication error. Performing a factory default reset does not help. Status lights on back of the camera appear normal and the camera responds to ping commands. Source string is;
"rtsp://root:pass@192.168.1.35:554/mpeg4/media.amp"
Any ideas?
burger
Re: Axis M1031-W
Post by burger »
Can you access the web server of the camera? Default is at 192.168.0.90
Are you sure you reset it correctly? See: https://www.axis.com/files/manuals/um_m ... n_1203.pdf
Also axis has their own forums. Try there. Link back if you post there.
fastest way to test streams:
