Page 1 of 2
Zoneminder 1.35.5~20200725145046-focal filters can't be saved
Posted: Sun Jul 26, 2020 5:53 pm
by bkjaya1952
In Zoneminder 1.35.520200725145046-focal , the filters conditional statements can't be saved.
In earlier versions , when there is an error , the log button color was changed into yellow or red . But that color change does not occur in the version 1.35.520200725145046-focal
Re: Zoneminder 1.35.5~20200725145046-focal filters can't be saved
Posted: Sun Jul 26, 2020 9:01 pm
by dougmccrary
Unsurprisingly, ditto in bionic.
I notice you can rename existing ones and make new ones.
Posted: Sun Jul 26, 2020 11:34 pm
by knight-of-ni
This was caused by yesterday's changes to Object.php. If you need to get this working now, you can roll back to the June 4 version of this file:
https://github.com/ZoneMinder/zoneminde ... Object.php
I've confirmed the filter problem goes away when using this version of Object.php.
Posted: Mon Jul 27, 2020 3:46 am
by bkjaya1952
Thank you Sir.
I have used June 4 version of Object.php as you suggested and working successfully
Posted: Mon Jul 27, 2020 4:48 am
by bkjaya1952
The above errors have not been resolved in latest update of Zoneminder 1.35.5~20200726223348-focal
Until make the corrections in the next release, we may have to use the solution given by Admin Eng knight-of-ni with his above post ,
(replacing Object.php at /usr/share/zoneminder/www/includes/ with June 4 version of Object.php)
Posted: Mon Jul 27, 2020 6:30 am
by dougmccrary
That one is now old.
1.35.5~20200726223348-focal works, at least so far as filters and colors (like for the LOG).
Posted: Mon Jul 27, 2020 3:59 pm
by bkjaya1952
dougmccrary wrote: ↑Mon Jul 27, 2020 6:30 am
Problems resolved only partially . Although the filters can be used, can't be saved. The change in colors of log button is also not solved completely.
Posted: Mon Jul 27, 2020 8:29 pm
by dougmccrary
Not sure about log.
But on the filters, did you reload the page? I can save filter changes no mine.
Posted: Fri Jul 31, 2020 5:00 pm
by bkjaya1952
dougmccrary wrote: ↑Mon Jul 27, 2020 8:29 pm
Not sure about log.
Hi dougmccrary
Yes you are correct . The filters can be saved in Zoneminder 1.35.5~20200726223348-focal . The change in color problem of log button still remains.
Posted: Sun Aug 02, 2020 6:56 am
by bkjaya1952
After the latest update of Zoneminder 1.35.5~20200801102905-focal all the problems have been solved !!
1. Filters can be saved
2. The color change in log button is OK
Posted: Mon Aug 03, 2020 4:36 pm
by Painter
It looks like new issues have been introduced though...
1) In every page i've been i noticed an auto-refresh of the page every 5 seconds. If i have selected let's say some events or if i want to delete some i have to be very fast an press delete/save or whatever. The same applies of course when in the system menu options.
Connected to the above, when playing back an event i cannot play it for the full length as it restarts from the beginning every 5".
2) At the "RUNNING" button on the top right with the options to select the ZM running state, i use to have start/stop/restart (or something similar)
Now i only have Start and default as options.
Posted: Mon Aug 03, 2020 5:04 pm
by knight-of-ni
1) is already fixed
2) aware of it. Haven't fixed it yet.
UPDATE: #2 is fixed
Posted: Mon Aug 03, 2020 7:03 pm
by Painter
Indeed, both are fine for me now. Impressed with the speed of the response.
Thanks!
Posted: Tue Aug 04, 2020 6:34 am
by dougmccrary
I'm seeing a refresh every minute on montage view, though. Not normal there, IIRC.
Posted: Tue Aug 04, 2020 12:02 pm
by knight-of-ni
A 1 minute full page refresh is by design and has been part of ZoneMinder for many years.
You can set the refresh period to whatever you want. It's under the High/Medium/Low B/W settings under options.
UPDATE: Annndddd.... you said Montage. I guess I should finish my morning coffee before posting. I'm not sure if the setting I mentioned affects that or not. Try it.
