zmNinja 1.4.009(android)
ZM 1.34.16
Hi All,
In zmNinja Events List, I have a thumbnail issue. The 1920x1080p standard camera thumbs look fine, and you can see the whole image, however, the fisheye camera I have, which has a resolution of 2048x2048, has the image squashed up and is only partly visible (you can only see about the top 20% and that's completely out of scale). Playback and montage/live view is fine, just the thumbnails for that particular camera in Events List.
I think this used to work OK I have a vague recollection it started doing it after either a ZM or zmNinja upgrade, but could be wrong.
Any thoughts would be welcome, be nice to get it working as I find the thumbnails quite helpful.
Cheers,
Dave
zmNinja Events Thumbnails Squashed for Fisheye Camera Only
Re: zmNinja Events Thumbnails Squashed for Fisheye Camera Only
Does clearing the zmNinja cache in menu help?
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
Thanks for the reply, unfortunately that didn't make any difference
Okay, most likely a CSS error on my side. Will test.
ES docs
zmNinja docs
ES docs
zmNinja docs
Thanks, hopefully something that can be sorted then.
