Segfaults in zoneminder-1.35.5-1.167.20200724gitg859428db5
torkilt
Post by torkilt »
After last upgrade all my monitors seem to segfault. Here's an example:
Aug 07 07:50:03 zm zma_m8[10531]: ERR [zma_m8] [Got signal 11 (Segmentation fault), crashing]
Aug 07 07:50:03 zm zma_m8[10531]: ERR [zma_m8] [Signal address is (nil), from 0x7fb1856d9ccf]
Aug 07 07:50:03 zm zma_m8[10531]: ERR [zma_m8] [Backtrace 0: /usr/bin/zma(_Z14zm_die_handleriP9siginfo_tPv+0x7a) [0x55f5bac98d2a]]
Aug 07 07:50:03 zm zma_m8[10531]: ERR [zma_m8] [Backtrace 1: /lib64/libpthread.so.0(+0xf630) [0x7fb184dc5630]]
Aug 07 07:50:03 zm zma_m8[10531]: ERR [zma_m8] [Backtrace 2: /lib64/libjpeg.so.62(+0x32ccf) [0x7fb1856d9ccf]]
Aug 07 07:50:03 zm zma_m8[10531]: INF [zma_m8] [Backtrace complete, please execute the following command for more information]
Aug 07 07:50:03 zm zma_m8[10531]: INF [zma_m8] [addr2line -e /usr/bin/zma 0x55f5bac98d2a 0x7fb184dc5630 0x7fb1856d9ccf]
??:0
??:0
??:0
[root@zm ~]# rpm -qa | grep zoneminder
zoneminder-common-1.35.5-1.167.20200724gitg859428db5.el7.x86_64
zoneminder-1.35.5-1.167.20200724gitg859428db5.el7.x86_64
zoneminder-httpd-1.35.5-1.167.20200724gitg859428db5.el7.x86_64
[root@zm ~]# cat /etc/redhat-release
CentOS Linux release 7.8.2003 (Core)
Any suggestions? Anything I can provide?
Thanks,
Torkil
Re: Segfaults in zoneminder-1.35.5-1.167.20200724gitg859428db5
Upgrade. That is a several weeks old snapshot. If you want to run bleeding edge development versions you have to at least update to the latest before you file a report.
I don't think he can at the moment. Fedora changed the %cmake macros we need to use in rpm specfiles, this caused all our redhat docker containers to fail, because they don't have those macros.
I just finished my first pass at upgrading all our redhat docker images and I'm watching the build progress to see if I got them all updated correctly.
el7 packages are now updating again on zmrepo. Yum should pick up the changes after your local yum cache expires, or after issuing "yum clean all".
torkilt
Post by torkilt »
Thanks.
I did of course check for a new version before posting, I should have made that clear 🙂
Mvh.
Torkil
