Page 1 of 1
Can't add IP-camera Nobelic NBLC-2231F-ASD
Posted: Sat Aug 08, 2020 11:35 am
by nabludatel
Hi, all!
I have link which good working in other software (rtsp://username:password@192.168.10.50/cam/realmonitor?channel=1&subtype=0).
BUT it don'r work in ZoneMinder.
Am I applying the wrong settings? Help please.
5 cameras work
3 cameras dont work
Re: Can't add IP-camera Nobelic NBLC-2231F-ASD
Posted: Sat Aug 08, 2020 2:26 pm
by bbunge
nabludatel wrote: ↑Sat Aug 08, 2020 11:35 am
Hi, all!
5 cameras work
3 cameras dont work
Are all your cams the same? If so you may be out of shared memory. Fix is to increase RAM or lower camera resolution.
Or, you may not be using a correct camera resolution in Zoneminder. A good check is to use VLC (Tools, Media Information, Codec) to check camera Display Resolution. Often the advertised cam resolution is different from what is actually used. And Zoneminder is picky.
Posted: Mon Aug 10, 2020 12:21 am
by nabludatel
Yes, you are right! I added RAM and it helped me.
