Zoneminder 1.35.5~20200808192924-focal , monitor setting gets empty popup window
bkjaya1952
Post by bkjaya1952 »
Today , I have tested Zoneminder 1.35.5~20200808192924-focal , which was released 4 hours ago .
When I try to adjust the brightness settings of the USB camera monitor , I get only a blank popup window. The monitor settings button did not work in all the recently issued Zoneminder versions.
However this problem is not not so important as the brightness settings of the USB camera can be adjusted using gucview software .
Screenshot from 2020-08-09 10-06-22.png (266.64 KiB) Viewed 1155 times
I have not come across any other problem in Zoneminder 1.35.5~20200808192924-focal , other than the above monitor settings issue.
