Events will not delete
Posted: Tue Aug 11, 2020 10:47 pm
I've installed and run ZM on a couple of boxes and each time I've had the same troubles, I cannot get events to delete. Tech savvy but linux skills are 4/10. I have to look up how to do anything other than basic tasks but I can figure it out with help.
Clean install of Debian 10
ZM installed as shown here: No problems
https://wiki.zoneminder.com/Debian_10_B ... om_ZM_Repo
ZM will fill up my disk as designed and I've setup a filter to delete the following. (Unarchived && disk > 50% && storage area = Events)
Events = /home/zoneminder/events
The log entries are as follows:
2020-08-11 18:40:17 zmfilter_1 725 ERR Unable to delete event 331 as previous operations failed zmfilter.pl
2020-08-11 18:40:17 zmfilter_1 725 ERR Command '0 /home/zoneminder/events/2/2020-08-10/331' exited with status: 72057594037927935 zmfilter.pl
2020-08-11 18:39:17 zmfilter_1 725 ERR Unable to delete event 331 as previous operations failed zmfilter.pl
2020-08-11 18:39:16 zmfilter_1 725 ERR Command '0 /home/zoneminder/events/2/2020-08-10/331' exited with status: 72057594037927935 zmfilter.pl
2020-08-11 18:38:15 zmfilter_1 725 ERR Unable to delete event 331 as previous operations failed zmfilter.pl
2020-08-11 18:38:15 zmfilter_1 725 ERR Command '0 /home/zoneminder/events/2/2020-08-10/331' exited with status: 72057594037927935 zmfilter.pl
2020-08-11 18:37:14 zmfilter_1 725 ERR Unable to delete event 328 as previous operations failed zmfilter.pl
2020-08-11 18:37:14 zmfilter_1 725 ERR Command '0 /home/zoneminder/events/2/2020-08-10/328' exited with status: 72057594037927935 zmfilter.pl
The filters are running but they cannot remove the files. I've played with file permissions, setting /home/zoneminder/events to 777 doesn't change anything.
It seems like getting filters to work is a common problem and I'd like to get past this so that I can learn more about ZM.
