Zoneminder-master 1.35.6~20200823115401-focal is fine
bkjaya1952
Post by bkjaya1952 »
Today I have tested the latest Zoneminder-master 1.35.6~20200823115401-focal using the following docker image .
https://hub.docker.com/r/bkjaya1952/zon ... ker-latest
It is running nicely with beautiful new appearance and couldn't find any shortcoming accept the brightness adjustment settings button issue of the monitor.
No problems in creating monitors,emailing , uploading and exporting events.
Screenshot from 2020-08-24 11-15-03.png (326.3 KiB) Viewed 1322 times
Screenshot from 2020-08-24 11-20-11.png (372.97 KiB) Viewed 1322 times
Screenshot from 2020-08-24 11-21-53.png (228.85 KiB) Viewed 1322 times
Re: Zoneminder-master 1.35.6~20200823115401-focal is fine
please test latest build I just pushed. Should have fixes for the settings popup.
bkjaya1952
iconnor wrote: Tue Aug 25, 2020 4:42 pm please test latest build I just pushed. Should have fixes for the settings popup.
I have tested Zoneminder master 1.35.6~20200825114814-focal . But still gets an empty window when you try to save the changes.
Screenshot from 2020-08-25 23-28-33.png (268.15 KiB) Viewed 1281 times
Screenshot from 2020-08-25 23-28-59.png (252.41 KiB) Viewed 1281 times
Screenshot from 2020-08-25 23-29-28.png (44.66 KiB) Viewed 1281 times
