Maybe a preference, but
2020-08-23 23:32:15 zms_m11 64354 ERR Monitor 11 has function NONE. Will not be able to connect to it. zm_stream.cpp 48
seems like a WARning, or even INFo?
1.35.6~20200823115401-focal looking good
Re: 1.35.6~20200823115401-focal looking good
Well the question is, how did you get there?
Nowhere should it list a camera that isn't capturing
Weird.
I was trying to figure it out, and got it stopped. Then it wouldn't start again
Or at least I've not seen it again. Ugh.
OK - on 1.35.6~20200827192711-bionic
I notice the console direct function is inop - won't save. Anyway.
Select a monitor that's running normally. Specifically in my case, mocord / enabled.
Using the source from console, set function to NONE.
Observe zms_mn errors.
