Page 1 of 1
overwriting old recordings
Posted: Tue Sep 01, 2020 5:54 am
by petec
where can I find this setting if filesystem is fullfiled?
Re: overwriting old recordings
Posted: Tue Sep 01, 2020 6:36 am
by dougmccrary
Uhm, read the docs,
but usually it's filter one, PurgeWhenFull.
If you built a new system on a previously used disk, you'll generally need to delete the old ones yourself, AFAIK.
You probably should be running a release version until you get your feet wet with this software.
This 1.35 is developmental.
