Test run on Zoneminder master 1.35.6~20200903182515-focal
- bkjaya1952
I have tested the latest update of Zoneminder master 1.35.6~20200903182515-focal released today with USB camera monitor .
1. The problem in Function model of the previous release (1.35.6~20200902181741-focal ) has been fixed successfully in Zoneminder master 1.35.6~20200903182515-focal .
2. Uploading and e- mailing of motion detection events can be done without any problem
I have not come across any other problem in this release
- knight-of-ni
Re: Test run on Zoneminder master 1.35.6~20200903182515-focal
Thank you for the daily test reports. It has been particularly helpful.
- bkjaya1952
Thank you Sirknight-of-ni wrote: ↑Fri Sep 04, 2020 1:15 pm Thank you for the daily test reports. It has been particularly helpful.
You probably didn't try any of the montage layout/size options. They appear to work/drop down, but have no effect.
- bkjaya1952
Hi dougmccrarydougmccrary wrote: ↑Sat Sep 05, 2020 12:27 am You probably didn't try any of the montage layout/size options. They appear to work/drop down, but have no effect.
Yes you are correct .
Scale menu does not work in Monitor and Montage .
Figure 1 Trying to change scale using Monitor Sale menu
Figure 2 error log when trying to change the scale of the monitor
Figure 3 error log when trying to change the scale of the montage
This testing a great work, but I might make a suggestion that if you are going to do the work that you look into automating it. Once that is done perhaps we can add it the automated testing to our build system.
I have no idea what what testing infrastructures might be relevant/useful, but even figuring that out is valuable research.
In the meantime I'll go fix the scale options..
- bkjaya1952
Thank you Sir! We greatly appreciate your work on upgrading our favorite opensource software ,Zoneminder .iconnor wrote: ↑Sat Sep 05, 2020 12:33 pm This testing a great work, but I might make a suggestion that if you are going to do the work that you look into automating it. Once that is done perhaps we can add it the automated testing to our build system.
- bkjaya1952
Please run the latest Zoneminder 1.35.6~20200905091552-focal where the layout/size options buttons removed.dougmccrary wrote: ↑Sat Sep 05, 2020 12:27 am You probably didn't try any of the montage layout/size options. They appear to work/drop down, but have no effect.
Figure 1 Montage view with removed layout/size options buttons
Figure 2 Montage Review with scale slider in the menu and - + buttons on the picture to adjust the scale
Scale slider and - + buttons works well to adjust the scale with out any problem
Apparently the montage scale problem has been solved .
But the Scale adjustment drop down menu of the Monitor is still not working .
The error log for Scale adjustment drop down menu is shown below
Yes, it's working as it has.
It may be by design, but the Scale becomes "Fixed width/Height" when any other button is used, and when the scale is changed, the "layout" setting is ignored. Works well otherwise.
- bkjaya1952
The above problem seems to be fixed in the latest release of Zoneminder master 1.35.6~20200908111355-focaldougmccrary wrote: ↑Sat Sep 05, 2020 9:22 pm Yes, it's working as it has.
OK, let me add this:
The problem occurs when the the layout width forces a change to the set scale.
Then changing the scale just ignores the set width, although the set width is displayed unchanged.
- bkjaya1952
Please check the zoneminder master released today . The above problem has been fixeddougmccrary wrote: ↑Wed Sep 09, 2020 7:13 am OK, let me add this:
...111355 is what I'm talking about.
But I'm going to re-install from scratch to be sure something else isn't going on.
I'm doing that because -focal and -bionic are behaving slightly differently on my systems.
...and now I see ...150915 out...
new install with 1.35.6~20200909150915-focal -
I dunno - you must be doing something different.
How many monitors are you testing with?
Might take two or four...
