Page 1 of 1
log not filter
Posted: Wed Sep 16, 2020 11:05 am
by Cramac1
Hello. Install 1.35.6
filter stopped working in logs
Re: log not filter
Posted: Wed Sep 16, 2020 2:09 pm
by iconnor
Just pushed a fix. packages building.
Re: log not filter
Posted: Thu Sep 17, 2020 7:24 am
by bkjaya1952
iconnor wrote: ↑Wed Sep 16, 2020 2:09 pm
Yes ! The fix is working in Zoneminder master 1.35.6~20200916100837-focal
- Untitled.png (853.09 KiB) Viewed 4557 times
Re: log not filter
Posted: Thu Sep 17, 2020 9:25 pm
by ovargaspcr
It did fixed the problem with the log filters, but I don't know if it's just me but now I have problems if I try to delete a zone on any of the monitors. Delete option is not working at all.
Re: log not filter
Posted: Fri Sep 18, 2020 12:59 am
by iconnor
delete zone is fixed
Re: log not filter
Posted: Fri Sep 18, 2020 7:42 pm
by ovargaspcr
Thanks iconor, I'm still unable to delete zones with the latest package version. Deleted and reinstalled zoneminder and didn't fix it. So I allowed myself (hope you don't mind) to look at the code of the version I've installed (I used to code a long long time ago and not on php) and did little
- zones.txt
- had to rename it to txt, doesn allow to attach php files, original lines are commented out next to the lines that I changed.
- (1.92 KiB) Downloaded 166 times
changes to it. It seems to be working on my installation for the little testing I did (by pure luck). I'm not sure again if it's the latest version that I'm using, but this is what I did to the /includes/actions/zones.php file (attachment)
regards
Ovargasp
Re: log not filter
Posted: Fri Sep 18, 2020 10:30 pm
by iconnor
yeah that's not based on today's code.
We are no longer concerned with mid, only zid... gettid?
Instead of looking at what packages are available you might want to follow commits on github. Prepare to marvel at the brevity of our commit messages!
Keep testing. Things will smooth out soon I'm sure.. or we will break them REALLY GOOD!
Re: log not filter
Posted: Fri Sep 18, 2020 11:03 pm
by ovargaspcr
OK I'll do that, thanks again for your help.
regards
Ovargasp
Re: log not filter
Posted: Fri Sep 25, 2020 8:17 pm
by Cramac1
log update is not convenient. I do not have time to set the filter, as the page is refreshed.
