Issues with storage
Posted: Fri Sep 18, 2020 2:39 pm
I have two issues that may or may not be related.
The first is that I am using freenas to store all of the footage from zoneminder and followed this tutorial from the wiki: https://wiki.zoneminder.com/Common_Issu ... ive_or_NAS
When the VM boots the storage fails to mount. When I looked at systemctl status this is what returned:
I did go through and double check to make sure that all of the storage configuration information that I had entered was correct.
I've been making sure that I mount the storage right after the vm boots and then start zoneminder. After zoneminder starts I get this warning for most if not all of my cameras 1 minute apart:
I've double checked the storage tab for each source and they all list "default" as the storage destination. There aren't any other storage options configured. Also alarms are recorded and playback without any issues.
I'm happy to provide additional info that would help troubleshoot the issues. Any suggestions on how I could resolve all of this would be greatly appreciated.
Sep 04 06:47:31 zimmzones mount[895]: mount error(2): No such file or directory
Sep 04 06:47:31 zimmzones mount[895]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
Sep 04 06:47:21 zimmzones systemd[1]: mnt-xvda2.mount: Directory /mnt/xvda2 to mount over is not empty, mounting anyway.
Sep 04 06:47:21 zimmzones systemd[1]: Mounting systemd mount unit for ZoneMinder event storage...
Sep 04 06:47:28 zimmzones systemd[1]: mnt-xvda2.mount: Mount process exited, code=exited, status=32/n/a
Sep 04 06:47:28 zimmzones systemd[1]: mnt-xvda2.mount: Failed with result 'exit-code'.
Sep 04 06:47:28 zimmzones systemd[1]: Failed to mount systemd mount unit for ZoneMinder event storage.
DiskSpace: Event does not exist at /var/cache/zoneminder/events/4/2020-08-20/7224:ZoneMinder::Event: AlarmFrames => 10 AvgScore => 50 Cause => Linked DefaultVideo => 7224-video.mp4 EndTime => 2020-08-20 14:17:04 Frames => 51 Height => 1920 Id => 7224 Length => 10.60 MaxScore => 50 MonitorId => 4 Name => Event- 7224 Notes => Linked: Small Room Sub Orientation => ROTATE_0 SaveJPEGs => 3 Scheme => Medium StartTime => 2020-08-20 14:16:54 StateId => 2 TotScore => 500 Width => 2560
