Page 1 of 1
Raspberry PI cam setup (local, on board with the zoneminder install)
Posted: Sat Sep 19, 2020 9:13 pm
by mlw19mlw91
Hey guys, I have zone minder on a raspberry pi 4b with the rpi cam and I can not figure out how to access it. I've tried a few things but nothing works. Please help! What's the path? What's the caputre mentod? Is it local, as far as the source type goes?
I promise I'll put this in the WIKI after
Re: Raspberry PI cam setup (local, on board with the zoneminder install)
Posted: Fri Sep 25, 2020 8:09 pm
by burger
General RPI info is covered in wiki.zoneminder.com/Single_Board_Computers
For the camera, there are numerous guides online that cover setup. Did you search?
https://raspberrypi.stackexchange.com/q ... tion#26386
I recommend you test in ffmpeg or vlc first (probably ffmpeg, since you shouldn't have X on the RPI). e.g.
If it's /dev/video0 it would be local. You will need to know the resolution (ffmpeg will tell you this).
