when I look at the timeline of a monitor and switch backwards or forwards, the timelines of all monitors suddenly appear instead of the corresponding section of this one monitor.
Can it be fixed please?
My version is zoneminder 1.35.6~20200920.388-buster amd64.
Thanks and Regards...
Re: timeline of a monitor
I also noticed that when you zoom into the timeline of a monitor by clicking on the white area, you also switch to the simultaneous display of the timelines of all monitors.
Unfortunately, it is no longer possible to work properly with the timeline.
Greetings
Daniel
Greetings
Daniel
It works again since today's update (1.35.6~20200924.434-buster).
Thank you so much!
Regards...
Thank you so much!
Regards...
