Page 1 of 1
[Solved]Zoneminder master 1.35.6~20200921172458-focal - modect to motion change dosen't stop recording
Posted: Tue Sep 22, 2020 6:28 am
by bkjaya1952
Today I have tested Zoneminder master 1.35.6~20200921172458-focal .
I have found a minor problem in motion detection recording .
The motion detection event recording does not stop ,if I change the monitor status from modect to monitor using the drop down menu .
The recording stops only after restarting Zoneminder .
I didn't find any other problem.
Screenshot from 2020-09-22 11-23-00.png (223.39 KiB) Viewed 3020 times
The above error still remains in Zoneminder master 1.35.6~20200922155244-focal released on 23-9-2020
The above error still remains in Zoneminder master 1.35.6~20200923161646-focal released on 24-9-2020
The above error still remains in Zoneminder master 1.35.6~20200925160318-focal released on 26-9-2020
Re: Zoneminder master 1.35.6~20200921172458-focal - modect to motion change dosen't stop recording
Posted: Wed Sep 30, 2020 2:39 pm
by sammael
As a workaround not requiring restart it works when you change modes from within monitor settings and saving the changes.
Posted: Wed Sep 30, 2020 3:57 pm
by bkjaya1952
This problem has been fixed in the latest Zoneminder master 1.35.8~20200930093952-focal released today.
Thanks for solving the the problem.
Screenshot from 2020-09-30 21-19-13.png (455.56 KiB) Viewed 2900 times
Posted: Wed Sep 30, 2020 4:00 pm
by bkjaya1952
sammael wrote: Wed Sep 30, 2020 2:39 pm As a workaround not requiring restart it works when you change modes from within monitor settings and saving the changes.
The problem has been solved by Mr. Isaac Connor in the latest Zoneminder master 1.35.8~20200930093952-focal released 2 hours back.
Restarting is not required .
