Improving performance in constant preview scenario
Ninjago
Post by Ninjago »
Hello fellow CCTV amateurs.
I am trying to use zmNinja in a Security Room / Constant Preview of all monitors, scenario.
I am obligated to store X days of constantly recorded footage, relying on Modect and Alarms is not enough.
I also need to provide constant stream of all monitors to a Security Room.
My system handles perfectly well 800x600, 6fps constant recording, but the moment I open "Montage" view in zmNinja, system gets overloaded (8core system gets 12 load) and parts of the recorded footage get dropped.
Any recommendations, how to tackle this problem?
Re: Improving performance in constant preview scenario
Step 1: Throw money at the developers.
I'm not sure how exactly zmNinja does the montage streaming but it is likely you could get by with a lower fps than you are capturing or perhaps a low resolution.
I recently discovered that passing width=&height= to zms doesn't actually do anything. It only understands scale= so I will have to consult with the auther of zmNinja and make sure he is aware of that.
800x600 is kindof an odd resolution for cameras, are you maybe doing some unnecessary scaling? Other than that, make sure you are using libjpeg-turbo or free up more resources. You will need to figure out exactly what is taking up the resources.
asker
Post by asker »
You are most likely not using multi-port streaming. My guess is that is the big ticket item.
There are other tips: https://zmninja.readthedocs.io/en/lates ... -my-server
zmNinja doesn't use width/height for montage. It uses scale
Please read before posting:
ES docs
zmNinja docs
tommisgr
Post by tommisgr »
Use low bandwidth option in zmninja settings.
Every monitor will update every 10 secs or something.
i think there is an option to change that.
