Page 1 of 1
PC power savings modes with Zoneminder?
Posted: Mon Sep 28, 2020 5:54 pm
by homebrewdude
This might be a silly question...
I looking to reduce the power consumption of my PC running zoneminder.
I am assuming I can't have it in sleep mode? It won't record then?
Any thoughts or suggestions on what I am trying to do?
Re: PC power savings modes with Zoneminder?
Posted: Tue Sep 29, 2020 6:56 am
by dougmccrary
How 'bout a lower power machine just for zm?
At least you can turn off the monitor, if it's using one.
Posted: Fri Oct 02, 2020 1:28 am
by bbunge
Set up a headless Linux server. Install a minimal command line system with LAMP or LEMP. Use low resolution (640x480) and frame rate (5 FPS) on your monitors using MODECT. SSD for the OS and Data and a WD Green HD for storage.
If you want really low power use a Pi 3 or 4 but you will be limited in the number of monitors you can run.
Posted: Wed Nov 04, 2020 4:20 am
by homebrewdude
I have a small NUC system, I could use.
But it won't have the storage on it.
Will I just bog down my network with the camera feeds, then the transfer of recordings to my second machine with HD space?
Posted: Wed Nov 04, 2020 8:55 am
by dougmccrary
You haven't said how many cams or what resolutions you're planning on.
I have 11 cams mostly at 640 or 1280 and about 6 FPS. Unless you have an 802.11 a or b network, bandwidth won't be a problem. I hardly ever see more than 2 or so mbps in, and 3 or 4 out, with two machines running montage.
And from what I can see, you can either outrig a sata drive or use usb on the nuc, if you have something laying around. You can network storage as well, with around the same as camera stream bandwidth.
Posted: Wed Nov 04, 2020 5:33 pm
by homebrewdude
7 cameras, all hardwired with POE switches
10fps set on the cameras.
They range from 1080 or higher
Looking at zoneminder I am currently 1.7MB/s
Posted: Wed Nov 04, 2020 10:58 pm
by dougmccrary
That sounds manageable, even with remote storage.
Although I just did an update which is not connecting any camera, so you might want to start the nuc on a release version.
