disk usage display in wui
fiberman
Post by fiberman »
the used hard disk space is displayed for each monitor in the Zoneminder web interface.
However, the values don't seem correct to me. In my opinion, there is too little displayed.
If I verify this directly in the filsystem, my suspicions are confirmed.
Why are the values in the web interface incorrect?
I use zoneminder 1.35.9~20201007.66-buster amd64.
regards
Daniel
Re: disk usage display in wui
What is probably happening is that the Update Disk Space filter is matching events that are in progress, so it stores an early value and then the record never gets updated.
In 1.34 and before we automatically added an EndTime IS NOT NULL clause to filters. This prevented them from matching in progress events, but sometimes we WANT to match in progress events.
So now you have to explicitly say in the filter whether you want to match in progress events.
So check your filter and see if it has an EndTime IS NOT NULL clause.
fiberman
Post by fiberman »
Hello, I have adjusted the filter.
The console now shows correct values for the hard disk space consumption.
Many Thanks! :)
