Frame image missing with alarmed area
Posted: Sun Oct 11, 2020 6:03 am
When I check the max. score of an event, the frame popup does not show the alarmed frame image in case the scale has been set to "Scale to Fit" before. Manually changing the value still shows the images with the alarmed areas. It looks as if a line of code is somewhere missing.
My zoneminder version is 1.34.21 rununing on Centos 7 and an running exceptionally well.
