Page 1 of 1
Pictures in Notifications
Posted: Sun Oct 11, 2020 4:34 pm
by bodgit
Due to a hardware failure (Dont buy cheap SSDs) I have done a clean install on a Raspberry Pi 4/4.
Ubuntu 20.04
Zoneminder 1.35.9
Event Server v5.15.6 (Not using hooks)
zmNinja Pro v1.4.009 (Android)
Every thing working well with the exception of pictures in Notifications
I am not even getting the white space in the notification for the picture.
As a test
Part of my zmeventnotification.ini
include_picture = yes
picture_url =
https://upload.wikimedia.org/wikipedia/ ... n_2014.jpg
#picture_portal_username=!ZM_USER
#picture_portal_password=!ZM_PASSWORD
I read and reread the faq,s no luck even tried another phone with no luck, can any body help with this.
Re: Pictures in Notifications
Posted: Sun Oct 11, 2020 8:45 pm
by asker
Are you absolutely sure you are on 5.15.6 and not master? If you are on master, try a smaller image (1MB or less)
If you are on 5.15.6, you'll need to post DEBUG logs when the push is being sent out from the ES
Posted: Sun Oct 11, 2020 8:55 pm
by bodgit
I assumed i am on version 5.15.6 because the first line of CHANGLOG.md reads:-
## [v5.15.6](
https://github.com/pliablepixels/zmeven ... ee/v5.15.6) (2020-06-30)
Will post debug logs.
Posted: Sun Oct 11, 2020 9:02 pm
by bodgit
CONSOLE DBG-2:2020-10-11,17:00:29 |----> FORK:Roaming (1), eid:903 fcmv1: FCM called when there is no start hook/or hooks are disabled, so making sure we do not use objdetect in url
CONSOLE DBG-2:2020-10-11,17:00:29 |----> FORK:Roaming (1), eid:903 fcmv1: Final JSON using FCMV1 being sent is: {"image_url":"
https://upload.wikimedia.org/wikipedia/ ... jpg","body":" at 05:00 PM, 11-Oct","token":"dKlyUvjQ0Z4:APA91bE5FKk8gll0VMErygnKLoIdJZ0q_WGvxhxsgDqbBv66eijJsjIwawrrOTgSUfWiD3lHh2imNxaHekbRm7ZMQEVbXYfw3YuML9sXxtX2cuhOY3Fj1fhrnNB-dPFJj9do8bgZhNOS","data":{"mid":"1","notification_foreground":"true","eid":"903"},"sound":"default","badge":2,"title":"Roaming Alarm","android":{"icon":"ic_stat_notification","channel":"zmninja","priority":"high"}} to token: ...gZhNOS
CONSOLE DBG-1:2020-10-11,17:00:30 |----> FORK:Roaming (1), eid:903 fcmv1: FCM push message returned a 200 with body {"Success":"projects/ninja-1105/messages/0:1602450030290033%311426be311426be"}
Posted: Sun Oct 11, 2020 9:32 pm
by asker
No this is ES 6. I assume you are not getting any notifications. Not just images?
For now don’t check out master (which is what you did). Check out a stable release.
Posted: Sun Oct 11, 2020 9:50 pm
by bodgit
Hi Asker
No I am getting notifications as normal just not the pictures.
I used:-
git clone
https://github.com/pliablepixels/zmeven ... cation.git
cd zmeventnotification
From the installation instructions for stable release
I have just redownloaded and the CHANGLOD.md is the same
Am I doing something realy stupid (Not unknown)
Posted: Sun Oct 11, 2020 10:20 pm
by bodgit
I think I have sused out what I have been doing wrong.
I thought that for a new install you just had to do the first two lines of the instructions and the last two lines were for updating. Duh
I,m going away to bang my head on a brick wall and try again tomorrow.
Apologies for any trouble caused..
