Page 1 of 1
Automatically Updated to 1.35.6 Lots of broken stuff
Posted: Tue Oct 27, 2020 6:05 pm
by asprinkem90
I've never really had problems with the auto updates before but since this last one I have a lot of broken things. If I try to audit events report I get this error:
2020-09-11 01:18:27web_js6064ERRTypeError: minTime_element[0].form is nullzm/cache/skins_classic_views_js_report_event_audit-classic-1599780478.
I also seem to have issues with how it is calculating file size. It seems to max out at counting 29gb worth of events for all cameras.
I have also found I can't load events on mobile either as the web page gets cut off and wont load, and if i can manage to navigate to an event it wont play. It only works on PC now.
I tried doing an uninstall and reinstall but no luck. It pulled the old config right back in and I still have all the same issues.
Re: Automatically Updated to 1.35.6 Lots of broken stuff
Posted: Wed Oct 28, 2020 1:30 pm
by iconnor
1.35.6 is pretty old as far as the 1.35 series goes.
Furthermore it is considered bleeding edge. If you don't want things to break, stay on 1.34.
