When you clone a monitor, it copies everything across perfectly apart from zones. The zones are not cloned with the monitor and instead it just defaults to one "All" zone.
Is that a bug or is that by design?
Possible bug with cloning monitors
Re: Possible bug with cloning monitors
It’s the current design, but is down as a feature on GitHub. Someone needs to spend the time doing the work.
Okay cool, thanks for the reply. I'm a C# developer by day but maybe if I find some spare time I'll see if I can turn my hand to this.
